PlayStation 5 EMC Errlogs
Device(s) PlayStation 5, PlayStation 5 Slim, PlayStation 5 Pro
Difficulty
What are Errlogs ?
Code Description
80000001 Failed To Access Thermal Sensor
80000004 AC/DC Power Fail
80000005 Main SoC CPU Power Fail
80000006 Main SoC GFX Power Fail
80000007 Main SoC Thrm High Temperature Abnormality
80000008 Drive Dead Notify Timeout
80000009 AC In Detect(12v)
8000000A VRM HOT Fatal
8000000B Unexpected Thermal Shutdown in state that Fatal OFF is not allowed
8000000C MSoC Temperature Alert
80000024 MEMIO(2) Init FAIL(SoC) (?)
80800024 Fatal Shutdown by OS request
80850000 VRM CPU (2)
80860000 VRM GPU(6)
80810001 Power Seq Error
80810002 Power Seq: NVS Access Error
80810013 Power Seq: ScCmd DRAM Init Error
80810014 Power Seq: ScCmd Link Up Failure
80830000 Main SoC Sync Flood
80870001 Titania RAM Protect Error
80870002 Titania RAM Parity Error
80870003 Titania Boot Failed : Couldn't read Chip Revision.( Check Fuse F7001)
80870004 Titania Boot Failed : Couldn't read error information.
80870005 Titania Boot Failed : State Error
808D0000 Thermal Shutdown : Main SoC
808D0001 Thermal Shutdown : Local Sensor 1
808D0002 Thermal Shutdown : Local Sensor 2 “Problem with the temperature sensor on the LED board — check the flex cable/LED Board. If the error happens without the flex and LED Board connected the Southbridge is probably faulty. Name of the faulty line [THERMISTOR_2_LED]”
808D0003 Thermal Shutdown : Local Sensor 3
808E0000 EAP_Fail (SSD_CON)
808E0001 EAP_Fail (SSD_CON)
808E0002 EAP_Fail (SSD_CON)
808E0003 EAP_Fail (SSD_CON)
808E0004 EAP_Fail (SSD_CON)
808E0005 EAP_Fail (SSD_CON) - Sig 1
808E0006 EAP_Fail (SSD_CON)
808E0007 EAP_Fail (SSD_CON)
808F0001 SMCU (SSD_CON > EMC) (?)
808F0002 SMCU (SSD_CON > EMC) (?)
808F0003 SMCU (SSD_CON > EMC) (?)
808F00FF SMCU (SSD_CON > EMC) (?)
80C00114 WatchDog For SoC
80C00115 WatchDog For EAP
80C0012C BD Drive Detached
80C0012D EMC Watch Dog Timer Error
80C0012E ADC Error (Button)
80C0012F ADC Error (BD Drive)
80C00130 ADC Error (AC In Det)
80C00131 USB Over Current
80C00132 FAN Storage Access Failed
80C00133 USB-BT FW Header Invalid Header
80C00134 USB-BT BT Command Error
80C00135 USB-BT Memory Malloc Failed
80C00136 USB-BT Device Not Found
80C00137 USB-BT MISC Error
80C00138 Titania Interrupt HW Error
80C00139 BD Drive Eject Assert Delayed
80801101 RAM GDDR6 1
80801102 RAM GDDR6 2
80801103 RAM GDDR6 1 2
80801104 RAM GDDR6 3
80801105 RAM GDDR6 1 3
80801106 RAM GDDR6 2 3
80801107 RAM GDDR6 1 2 3
80801108 RAM GDDR6 4
80801109 RAM GDDR6 1 4
8080110A RAM GDDR6 2 4
8080110B RAM GDDR6 1 2 4
8080110C RAM GDDR6 3 4
8080110D RAM GDDR6 1 3 4
8080110E RAM GDDR6 2 3 4
8080110F RAM GDDR6 1 2 3 4
80801110 RAM GDDR6 5
80801111 RAM GDDR6 1 5
80801112 RAM GDDR6 2 5
80801113 RAM GDDR6 1 2 5
80801114 RAM GDDR6 3 5
80801115 RAM GDDR6 1 3 5
80801116 RAM GDDR6 2 3 5
80801117 RAM GDDR6 1 2 3 5
80801118 RAM GDDR6 4 5
80801119 RAM GDDR6 1 4 5
8080111A RAM GDDR6 2 4 5
8080111B RAM GDDR6 1 2 4 5
8080111C RAM GDDR6 3 4 5
8080111D RAM GDDR6 1 3 4 5
8080111E RAM GDDR6 2 3 4 5
8080111F RAM GDDR6 1 2 3 4 5
C0020303 Main SoC Access Err (SB-TSI I2C)
80050000 SoC VRM Power Fail (CPU)
80801028 Fatal Shutdown by OS request
C0810002 HDMI Tx Access Error (Failure in the 1.8V power line of the HDMI Encoder) Name of the faulty line: [1.8V_HDMI] File:C0810002.jpeg
80918000 SSD PMIC Error (DA9081\RT5127 failure in the 0.8V line) Name of the faulty line: [0.8V_FC_VDD] File:80918000.jpeg
80912000 SSD PMIC Error (DA9081\RT5127 failure in the 2.5V line) Name of the faulty line: [2.5V_DDR4_VPP] File:80912000.jpeg
80910200 SSD PMIC Error (DA9081\RT5127 failure in the 1.2V line) Name of the faulty line: [1.2V_FC_VDDQMIO] File:80910200.jpeg
80910002 SSD PMIC Error (DA9081\RT5127 failure in the 1.8V line) Name of the faulty line: [1.8V_FC_AVDD] File:80910002.jpeg
C00C0002 VRM Controller Access Error (failure in the 3.3V VRM line) Name of the faulty line: [3.3V_VRM]
80C00140 Force Shutdown Power Button Pressed for 10 sec
80910800 SSD PMIC Error (Failure in the 1.2V_FC_VDDQFIO line) Name of the faulty line: [1.2V_FC_VDDQFIO]
808B00FF SSD Controller Watchdog Error
C0160203 PMIC (SSD) Access Error(Playstation 5 Slim Check F7004) ON EDM-03X Boards check F7502 File:C0160203.jpeg
B0088108 Sonics Bus Error
808C0D91 USB Type-C Error
80802081 Communication failure between the SSD controller and the APU — check the capacitors behind the controller. File:80802081.jpg
808010A5 Fatal Shutdown by OS request — I once had a PS5 Pro with this error and couldn’t figure it out. (IF YOU HAVE INFO PLEASE UPDATE THE WIKI)
8091C000 SSD PMIC Error
C0920002 USB Type-C Redriver Access Error
80802559 Fatal Shutdown by OS request (More Info needed)
808B0014 Flash Controller: Watchdog Timer (Related to the SSD)
80871055 Flash Cont (Related to the SSD)
80800014 Fatal Shutdown by OS request — supposedly related to the TPM chip.
8080001A Fatal Shutdown by OS request
80800022 Fatal Shutdown by OS request
80871001 Flash Cont: ScCmd Response Error
80871062 Flash Cont: ScCmd Response Error
80894003 Flash Cont: Boot EFC Error
808940AE Flash Cont: Boot EFC Error
808C2092 USB Type-C Error
80D00402 USB-BT Error (Download Firmware)
808011A0 RAM GDDR6 (Bank 6,8) - Single Beep, 1 second blue light, off.
B0082108 Supposedly related to the Wi-Fi chip.
80801F12 APU problems (Try reballing).
808300F1 Found in DB no info
80060004 Problem in a VRM
E31223DE Related to the Southbridge — clean the flux underneath or let it cool down.
E2E00F1D Related to the Southbridge — clean the flux underneath or let it cool down.
E2000000 Related to the Southbridge — clean the flux underneath or let it cool down.
E1200000 Related to the Southbridge — clean the flux underneath or let it cool down.
80808888 Fatal Shutdown by OS request
C0810303 Found in DB no info
80801580 APU problems (Try reballing).
