IPhone 8
Revision as of 16:05, 14 May 2025 by DentsasPanos (talk | contribs) (Added Known Good Mechanic Lightning Readings)
IPhone 8
Manufacturer Apple
Code name
Release date
Device type Phone
How To Fix an iPhone 8 That Has No Power. Does Not BootMain Logic BoardBGA
Soldering
3. Hard
How To Fix an iPhone 8 With No Image. Turns on but nothing shows on the screenMain Logic BoardBGA
Soldering
3. Hard
Soldering
2. Medium
How To Fix iPhone 8 Not Charging After Screen Repair. Stuck at 0% Battery LevelMain Logic BoardBGA
Soldering
3. Hard
How To Fix iPhone 8 Plus with Grayed Out WiFiMain Logic BoardBGA
Soldering
3. Hard
How To Fix iPhone 8 Stuck In DFU Mode. Error 4014Main Logic BoardBGA
Soldering
3. Hard
How To Fix iPhone 8 That Restarts When You Make A Phone CallFront Camera FlexPart replacement1. Easy
How To Fix iPhone 8 With Error 9. Bootlooping At Apple LogoMain Logic BoardBGA
Soldering
3. Hard
How To Fix iPhone 8 With No TouchMain Logic BoardBGA
Soldering
3. Hard
NAND
Soldering4. Specialist
How to Fix an iPhone 8 Plus boot looping on apple logo and random chargingMain Logic Board
Front Camera
Charging Port Flex
Soldering3. Hard
How to fix iPhone 8 with Grayed Out Speaker Button During Phone CallMain Logic BoardPart replacement1. Easy
IPhone 8 No Backlight or Dark Spot On Screen RepairMotherboardSoldering3. Hard
IPhone 8 Stuck in Searching or No Service RepairMotherboardSoldering3. Hard
IPhone 8 Unable To Activate RepairMotherboardSoldering3. Hard
