| How To Fix iPhone 8 Stuck In DFU Mode. Error 4014 | |
| Device | IPhone 8, IPhone 8 Plus |
| Type | BGA, Soldering |
How To Fix iPhone 8 Stuck In DFU Mode. When you try to update or restore, you will get iTunes Error Code 4014. The screen will stay dark or not lit up.
- You get no image from the screen
- You plug into computer and iTunes/3U tools detects it in DFU mode
- If you try to Update or Restore, you get these results:
- iTunes Error Code: Error 4014
- 3u Tools Easy Flash: Fails at 19%
Cause:
- Error 4014 is usually "NAND not detected".
Solutions:
- Check the caps around NAND to see if they're shorted.
- If there's a short, remove the shorted cap and try to boot the phone up.
- If no short, pull the NAND and connect it to the JC P13 NAND programmer and see if it's readable
- You can refer to this video for how to use the P11F Programmer: https://youtu.be/J6n2Bj7sG5A
- If it doesn't read, the NAND is dead and needs to be replaced
- If it does read a NAND, then you can reball NAND and install it again. The phone should boot right up.
