| How To Fix iPhone 8 That Restarts When You Make A Phone Call | |
| Device | IPhone 8, IPhone 8 Plus |
| Affects part(s) | Front Camera Flex |
| Needs equipment | Screwdrivers, known good parts, spudger |
| Type | Part replacement |
How To Fix iPhone 8 That Restarts When You Make A Phone Call.
When you make a call, the phone will instantly restart or shut off.
Testing and Solution:
- Unplug the Front Facing Camera, then test again
- If the issue is solved, then plug in a new front-facing camera flex cable and try again
Explanation:
Usually this is caused by the ALS or proximity sensors getting some corrosion from liquid damage.
It's easier to just replace the part, but sometimes, you can clean off the corrosion with a toothbrush and isopropyl alcohol and get the flex working again.
