Nvidia Pascal (GTX 1000) GPU Diagnosing Guide
Revision as of 15:20, 7 March 2024 by ASRepairs (talk | contribs)
Device(s) GTX 1060, GTX 1070, GTX 1070Ti, GTX 1080, GTX 1080Ti
Difficulty ◉◉◌◌ Medium
The Card Layout
GTX 1080 Reference board (Figure 1) *PCB Image courtesy of TechPowerUp*
12V rails
3.3V rail
Step 3: Powering on the card
Power sequence
Step 4: No Video Out
Memory problems
BIOS problems
Straps
GTX 1080 Straps location on the board. (Figure 2)
Schematic view of 1080 straps (Figure 3)
Crystal Oscillator
Location of the crystal oscillator on a reference GTX 1080 (Figure 4)
Dead PCIE data lanes
Dead Core
Faulty PEX_RST AND gate
Step 5: GPU outputs a picture
Artifacting
Crashing under load
Error 43
