IPhone 12 Mini
Revision as of 19:39, 27 February 2024 by VCCBoardRepairs (talk | contribs) (Added iPhone 12 mini repair manual id)
IPhone 12 Mini
Manufacturer Apple
Code name
Release date 2020-10-23
Device type Phone
WiFi IC
4. Specialist
iPhone 12 Mini Self Repair Store
Repair Manual ID: VXUZTC
