IPhone 12 Mini
Revision as of 09:05, 9 February 2024 by VCCBoardRepairs (talk | contribs)
IPhone 12 Mini
Manufacturer Apple
Code name
Release date 2020-10-23
Device type Phone
WiFi IC
4. Specialist
