| PlayStation 5 | |
| Manufacturer | Sony |
| Code name | Erebus |
| Release date | November 11, 2020 |
The PlayStation 5 (commonly referred to as PS5) is a home video game console developed by Sony. It is competing with Microsoft's Xbox Series X and S with the ninth generation of consoles.
| PS5 Standby Boot Sequence & Consumption Analysis | Troubleshooting/Diagnostics | 2. Medium |
| PlayStation 5 EMC Errlogs | Troubleshooting/Diagnostics |
| How To Repair PS5 Controller Not Working in Normal Mode but Works in Safe Mode | Main Logic Board | Soldering | 4. Specialist |
| PlayStation 5 3 beeps when power is plugged in | Motherboard | Soldering | 2. Medium |
| PlayStation 5 Disk to Digital Conversion | Motherboard Disk Drive | Soldering | 3. Hard |
| PlayStation 5 Fan not working | Motherboard | 2. Medium | |
| PlayStation 5 Fault Finding Using UART | Motherboard | 2. Medium | |
| PlayStation 5 No Image and No Sound | Motherboard | Soldering | 3. Hard |
| PlayStation 5 Not turning on repair | Motherboard | Soldering | 3. Hard |
| PlayStation 5 Overheating and Shutting down | Console | 1. Easy | |
| PlayStation 5 Single beep from power button every 30 seconds repair | Motherboard | Soldering | 3. Hard |
PS5 Screw Lengths, locations, and quantities.
EDM-010
EDM-010
EDM-020
EDM-020
EDM-032
EDM-032
EDM-033
EDM-033
PS5 HDMI Port Diode Mode Readings through Mechanic T-824 Tester
PS5 HDMI Diode Measurements of board without port installed. Used Fluke 115 multimeter - Red probe on ground black probe on respective pads..
PS5 EDM-020 USB 3.0 Diode Measurements
PS5 EDM-020 Power and Disk FPC Diode Measurements
PS5 EDM-020 M2 SSD FPC Diode Measurements
PS5 EDM-020 LED FPC Diode Measurements
PS5 EDM-020 Front USB Diode Measurements
PS5 EDM-020 LAN Port Diode Measurements
PS5 EDM-020 Disk Drive Data FPC Diode Measurements
PS5 EDM-020 FAN and Disk drive power Diode Measurements
Bios image Dumps [1]
| MN864739 | HDMI Encoder IC | Aliexpress and other suppliers | |
| CXD90061GG | Southbridge | Aliexpress or donor boards | |
| Dialog DA9081 | SSD and Nand PMIC | Aliexpress | |
| 25Q16JVNIM | BIOS IC | Aliexpress | |
| Dialog DA9065 | Southbridge PMIC | Aliexpress | |
| 0.1ub X5R 0603 16V | Small cap behind HDMI Port | Aliexpress | |
| CXD90062GG | SSD Controller | Aliexpress or donor boards |
