| MacBook Pro A2338 | |
| Manufacturer | Apple |
| Code name | A2338 |
| Release date | |
| Device type | Laptop |
| How To Repair a M Series MacBook Wifi Not Working By Replacing Wifi IC | Logic Board WiFi IC | Soldering | 4. Specialist |
| MacBook Pro A2338 Audio Not Playing From Internal Speakers | Motherboard Speakers | Soldering | 3. Hard |
| MacBook Pro A2338 Clicking sound from system board, showing 5v on USB-C amp meter repair | Motherboard | Soldering | 3. Hard |
| MacBook Pro A2338 Not Charging, .15A current draw at 20V | Logic Board | Soldering | 3. Hard |
| MacBook Pro A2338 Not turning on, 0.00 - 0.05A current draw at 5V repair | Motherboard | Part replacement | 3. Hard |
| MacBook Pro A2338 Not turning on, 0.20-0.25a current draw at 5V with power cycling of the USB-C amp meter repair | Motherboard | Soldering | 3. Hard |
| MacBook Pro A2338 Not turning on, current draw cycling between 0.00 and 0.45a at 5V repair | Motherboard | Soldering | 3. Hard |
| MacBook Pro A2338 camera not detected after history of liquid damage repair | Motherboard Camera Display assembly | Soldering Part replacement | 3. Hard |
Board 820-02020 Schematic: https://cdn.dorkydanny.org/MacBook/A2338/820-02020.bvr
