| IPhone 11 Pro Max | |
| Manufacturer | Apple |
| Code name | |
| Release date | 2019-09-20 |
| Device type | Phone |
| How To Fix an iPhone 11 Pro That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
| How to fix iPhone 11 stuck in recovery mode with failed at Rose Error -1 | Main Logic Board | Soldering | 4. Specialist |
| IPhone 11 Pro and iPhone 11 Pro Max Not Powering on, 2a or Higher Power Draw After Prompt to Boot | Motherboard | Soldering | 3. Hard |
Schematics for iPhone 11 Pro Max: https://www.sendspace.com/file/nqi4cz
