| Nvidia Pascal (GTX 1000) GPU Diagnosing Guide | |
| Type | |
| Device(s) | |
| Difficulty | |
The Card Layout
12V rails
3.3V rail
Step 3: Powering on the card
Power sequence
Step 4: No Video Out
Memory problems
BIOS problems
Straps
Crystal Oscillator
Dead PCIE data lanes
Dead Core
Step 5: GPU outputs a picture
Artifacting
Error 43
