| Steam Deck | |
| Manufacturer | Valve |
| Code name | |
| USB to FPC adapter to test the Controller board(s) | Controller board | 1. Easy |
Steam Deck
Steam Deck
- Controller Board pictures
ButtonBoard Rev. B - R back side
ButtonBoard Rev. B - L back side
- Schematics of the rev. B controller board (incomplete)
Power delivery IC of the rev B controller board
Right trigger circuit of the rev B controller board
Some connections of the RA4E1 MCU of the rev B controller board
Rumble circuit of the rev B controller board
Debug connector (TC-2050) of the rev B controller board
R1(Shoulder)/R4/R5/"..." Button circuit of the rev B controller board
FFC connectors (USB and connection to L board) of the rev B controller board
Schematic for the mode-switch circuit to switch the MCU to programming mode - rev B board (Renesas MCU)
