How To Fix an iPhone 14 Pro That Randomly Restarts
Revision as of 16:15, 31 May 2024 by VCCBoardRepairs (talk | contribs) (fixed 0x100000 code)
Device iPhone 14 Pro, iPhone 14 Pro Max
Difficulty ◉◌◌◌ Easy
Type Part replacement
There are many reasons that could cause an iPhone 14 Pro and iPhone 14 Pro Max to randomly restart every few minutes. For the iPhone 14 Pro series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 14 Pro series are:
  • Proximity Flex - This is the flex that is attached to the screen. It can easily be liquid damaged or torn during a screen replacement.
  • Power Button Flex - This is the flex that wraps around the logic board & controls the power button.
  • 2 Layer Sandwich - Requires the bottom layer of the 2 layer motherboard. If the Gyro U7300 is not detected, it will restart. It could have ripped pads on the top board for the Gyro lines.
If you see:
  • 0x80000 - it's the Proximity Flex Cable
  • 0x40000 - It's the Charging Port Flex
  • 0x100000 - It's the Power Button Flex
  • 0xc0000 - It's the Prox Flex and Charging Port Flex
    • Make sure both flex cables are plugged in
  • 0x180000 - It's the Prox Flex and Power Button Flex
  • 0x140000 - It's the Power Button and Charging Port Flex
  • 0x1c0000 - It's the Charging Port and Power Button Flex and Prox Flex
    • Make sure all 3 flex cables are plugged in
    • iPhone 14 Pro Max will restart when the Gyro is not detected on the top board, giving 0x20000 panic log
  • 0x20000 - It's a sandwich board issue.
    • This means the sandwich board has separated. It could require a sandwich reball or a bottom board swap.
    • Check Gyro U7300
    • Check the pads for the Gyro U7300: 542, 543, 544, 545, 546, 6, 248
  • 0x41 - It's a battery data issue.
    • Sometimes you'll see the battery percentage fluctuate or you'll randomly get a "non-genuine" message.
    • Check the battery connector pins. Sometimes they can bend out & battery won't make good contact.
    • Diode mode the battery connector pins & compare them to known good board
    • Test with a known good battery
    • Replace the battery connector
iPhone 14 Pro Max - This panic log says 0x41, which is related to battery data is missing.
Example of what you'll see in a panic-full file, where when there's a bad prox flex and bad charging port flex causing the 3 min restart.
Example of what you'll see in a panic-full file, where when there's a bad prox flex and bad power button flex causing the 3 min restart.
  • Bad or damaged flex
Please note: You MUST have the required flex cables, (Prox flex, Charging port flex, Power Button Flex, Sandwich reballed) plugged in. Otherwise, it WILL restart. You cannot troubleshoot this step by unplugging the bad flex.
