IPhone X
Revision as of 07:58, 22 May 2024 by VCCBoardRepairs (talk | contribs) (Added iPhone X Intel top board only dfu bypass)
IPhone X
Manufacturer Apple
Code name
Release date 2017-11-03
Device type Phone
How To Fix an iPhone X That Randomly RestartsMain Logic BoardPart replacement1. Easy
How To Fix iPhone X That Does Not ChargeMain Logic BoardBGA
Soldering
3. Hard
How To Fix iPhone X That Does Not Power OnMain Logic BoardBGA
Soldering
3. Hard
How To Fix iPhone X That Has No TouchMotherboard
Display assembly
Soldering3. Hard
How To Fix iPhone X That Is Bootlooping Error 4013Main Logic BoardBGA
Soldering
Teardown
Part replacement
Cleaning
3. Hard
How To Fix iPhone X With No Service or Always SearchingMain Logic BoardBGA
Soldering
3. Hard
How To Fix iPhone X With No WiFi. Grayed Out ButtonMain Logic BoardBGA
Soldering
3. Hard
NAND
Soldering4. Specialist
How to fix iPhone X with No Display or No ImageMain Logic BoardBGA
Soldering
3. Hard
IPhone X image no centered and iphone restartingMotherboardSoldering3. Hard
