| How To Fix an iPhone X That Randomly Restarts | |
| Device | iPhone X |
| Needs equipment | Screwdrivers, known good parts, spudger |
| Type | Part replacement |
There are many reasons that could cause an iPhone X randomly restart every few minutes. For the iPhone X, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone X is:
- Bad or Defective Battery - If the phone is not showing a percentage at the top of the screen, it means the battery data isn't being read by the device, causing the device to restart. So if you see your iPhone X says it's charging at 0%, that could be why it's restarting.
If you see:
- Check the mosfets Q3201 or Q3200 to see if broken or damaged
- Check the battery data pins (I2C0_SMC_TO_GG_SCL_CONN and I2C0_SMC_BI_GG_SDA_CONN) for a diode mode reading. If it's OL, then there's a disconnected line & it'll need to be investigated
- Bad or damaged flex
