AMD Navi (RX 5000 series) GPU Diagnosing Guide
Revision as of 16:05, 14 March 2024 by ASRepairs (talk | contribs) (Created page with "{{Explanatory Guide |Device=RX 5700, RX 5700XT |Type=Troubleshooting/Diagnostics |Difficulty=2. Medium }} '''''This guide is applicable to most Navi cards RX 5000 series. While some vendors may produce different PCBs or utilize distinct components, the general operational principles for these cards are typically consistent unless otherwise specified. This guide uses a reference RX 5700XT as an example.''''' Have any questions or need assistance with a specific GPU prob...")
Device(s) RX 5700, RX 5700XT
Difficulty ◉◉◌◌ Medium
The Card Layout
File:Navi Measurements.png
RX 5700 XT reference board front view (Figure 1)
PCB Image courtesy of TechPowerUp
Before proceeding, it's advisable to inspect the card for physical damage, especially in the case of cards without a backplate. They can easily lose some components on the back due to poor handling.
12V Rails
Begin by measuring the resistances of the 12V rail originating from the PCIe slot (first 3 pins or the inductor, see Figure 1).
Subsequently, measure each inductor for external power connectors (in case of multiple external power connectors, measure each inductor individually). Some cards use fuses on the input rails, measure both sides for continuity and then against GND.
The resistance value may vary from card to card, but it should generally be in the thousands+ Ω range. If you measure 50Ω or less (The computer may not turn on because the power supply activates overcurrent protection (OCP)) or you have a blown fuse, this means that you likely have a short on the card. Check: 12V Rail Short on Navi GPUs.
3.3V Rail
The card derives 3.3V power solely from the PCIe slot. It is obtained from the 4th pin going left from the PCIe key notch in the front and the 2nd and 3rd pins on the back going from the notch again (as depicted in Figure 1)
If you measure less than 50Ω on one or multiple base rails, you likely have a card with a short (OCP trigger, same as 12V short). Check: 3.3V Rail Short on Navi GPUs.
If there is no short on both of the base rails, you can continue with the troubleshooting.
Step 2: Minor Voltage Rails (5V, 1.8V, 0.75V, VCore/SOC, VPP, Vmem/VDDCI)
Check the resistance of the output of these rails and compare them with Figure 1. VCore has such low resistance that measuring its resistance may not be very useful. A more helpful approach is to measure its resistance against the 12V rails, not GND.
Step 3: Powering On the Card
Power Sequence
In most Navi GPUs, they typically activate in the following order:
5V → 1.8V → 0.75V → VCore/SOC → VPP → Vmem/VDDCI
For example, if the 5V rail doesn't activate, nothing else in the chain will activate either, which means no fan spin if there's an issue with 5V or 1.8V.
If you're missing one of them, refer to their respective pages for more details on how they work and potential issues:
Step 4: No Video Output
Memory Problems
BIOS Problems
If the memory is fine or the card isn't even detected in Linux, the issue is likely related to the BIOS. Check out the BIOS Problems on Navi GPUs page for more information.
Crystal Oscillator
Crystal oscillators, often marked with "Y" followed by a number, can occasionally fail, resulting in the card not booting up. In most Navi GPUs, the oscillator frequency is 27MHz. To test it, you'll need an oscilloscope or a multimeter with an Hz function that can exceed 27MHz.
PERST_BUF Signal
PERST_BUF signal schematic view. (Figure 2)
Start by checking all inputs, if one is missing trace it according to the schematic in figure 3 and replace the faulty components. If all the inputs are present but the output is low, check the Vcc pin and make sure the gate is powered (if not, maybe a cut trace), after that, replace it if all inputs and power is present on the gate.
Step 5: GPU outputs a picture
Artifacting
if you do not get memory errors then the core is very likely to be the issue.
Crashing under load
Error 43
Start by making sure the memory is fine as shown in the guide above, then check if the BIOS is not corrupted/modded (flash original bios from either TPU BIOS Library or manufacturer's site) and check the bios circuit as shown here: BIOS Problems on Navi GPUs.
