Xbox Series X
Revision as of 07:35, 27 February 2024 by Ben ProFixerr (talk | contribs) (Added Xbox Series X HDMI Port Diode Mode Readings through Mechanic T-824 Tester Image)
Xbox Series X
Manufacturer Microsoft
Code name Project Scarlett
Device type Game Console
Joey Does Tech -
Part Numbers
  • 20535-010E-02 I-PEX Evaflex 5-VS series connector (aka nexus connector or push-button connector)
An Alternative ESD Booster IC has been developed that brings back functionality and has been released Here
