Xbox Series X No Video Repair | |
Device | Xbox Series X |
Affects part(s) | Logic Board |
Needs equipment | Screwdriver set, tweezers, soldering iron, soldering station |
Type | Soldering |
No Display / No Video Output
- No Display / No Video Output
- Put your Xbox into low resolution mode. Low Resolution mode demonstration.
- Replace HDMI Cable
- Inspect HDMI Port for Damage
- Check EMI Filters Below Port
- Check HDMI Encoder (Possibly Not Available to Purchase)
- Check ESD Protection IC (Underside of Motherboard) - You could also bypass the ESD Protection IC by using the pinout shown. To be used for diagnostic purposes.
- Check 2151 5v Transistor. Can Be Replaced with Similar Transistor from OG Xbox One Ethernet Circuit
Here are replacment ESD Booster IC's to restore full functionality. There is an easy to solder in alternative and the original BGA IC.
Original BGA IC: Can be purchased here
Alternate Solder in PCB: Can be purchased here
