| IPhone 11 Pro Max | |
| Manufacturer | [[:Category:|]] |
| Code name | |
| Release date | |
| Device type | |
| How To Fix an iPhone 11 Pro That Randomly Restarts | Main Logic Board | Part replacement | 1. Easy |
| How to fix iPhone 11 stuck in recovery mode with failed at Rose Error -1 | Main Logic Board | Soldering | 4. Specialist |
| IPhone 11 Pro and iPhone 11 Pro Max Not Powering on, 2a or Higher Power Draw After Prompt to Boot | Motherboard | Soldering | 3. Hard |
