Wireless Controller for Xbox One
Revision as of 00:48, 17 January 2024 by HaileyKitty (talk | contribs) (added pic)
Manufacturer Microsoft
Code name Model 1537, Model 1697, Model 1708
Release date November 22, 2013
Device type Game Console
Controller variations:
The original two controller models (Models 1537 and 1697) have a different plastic trim around the Xbox logo and do not support Bluetooth. Model 1697 controllers added a 3.5mm audio jack, while Model 1537 controllers lack it.
The Xbox Elite Wireless Controller and Xbox Elite Wireless Controller 2 includes more features compared to regular controller, including replaceable sticks and d-pad, four paddle buttons to back and fully rebind able button layouts.
The third standard model (Model 1708) was released along with the Xbox One S and have Bluetooth connectivity and textured grips. The Xbox logo is now surrounded by the main plastic on the front of the body.
The fourth standard model (Model 1914) was released along with the Xbox Series X and Xbox Series S and has a slightly smaller body, a USB-C port instead of a Micro-B USB one, a Share button, and similar to the Elite Controller, it has a flat concave D-pad, textured grip and shoulder buttons. It's currently available in seven different standard colors, and numerous special edition colors.
Use with PC platforms:
Connections:
USB
  1. Use a USB cable to connect the controller to a USB port on the computer.
  2. The controller will automatically be recognized by the supported OS and install generic driver for it.
Notes
The type of USB port on the controller end varies depending on the controller model.
Bluetooth
Only Model 1708 and newer has built-in Bluetooth connectivity.
Windows 10 with Anniversary update and later is required.
It is recommended to only connect single controller with Bluetooth connection. Some accessories like headsets and chatpads do not work using wireless connection.
The ability to use Bluetooth Low Energy protocol was added to model 1708 via the 5.11.3116.0 firmware, while model 1914 has support for Bluetooth Low Energy out of the box.
There are multiple reports of Model 1708 controllers connected via Bluetooth causing FPS drops and stutters. These problems don't seem to happen on other Bluetooth controllers or when connected via a wireless adapter, and it's yet unknown whether the issue persists on the newer Model 1914 controllers.
  1. Press and hold the controller bind button between shoulder buttons for 3 seconds until Xbox button starts to blink.
  2. On Windows 10, access Bluetooth settings (Settings → Devices → Bluetooth), select Xbox Wireless Controller from the list and click Pair.
Notes
To shut down the controller, hold the Xbox button for five seconds.
Wireless Adapter for Windows
Available in two variants: An older, larger Model 1713 and a new, smaller Model 1790.
Supports up to 8 controllers.
Support for Windows 7 and Windows 8.1 were dropped for Model 1790.
  1. Connect the wireless adapter to PC and press the pair button.
  2. On the controller, press the controller bind button between shoulder buttons. Notes
Windows
Connecting the controller should automatically download and install latest drivers for the controller.
Supported features reWASD Steam Gamepad Phoenix Controller Companion
Vibrations
Impulse Trigger Vibration ✓ (1)
LEDs
Dead-zone adjustment
Multiple controllers
Chatpad
Headphone Jack
Keyboard & Mouse input emulation
Virtual Xbox controller emulation
Virtual DualShock emulation ✓ (2)
Virtual Nintendo controller emulation ✓ (3)
Retro DInput/WinMM compatibility ~ (4) ~ (4) ~ (4)
Battery status
Motion controls attachments ✓ (5) ✓ (6)
  1. Requires the Xbox Extended Feature Support driver to be installed through Steam.
  2. Allows using controller as DualShock 3 and DualShock 4 virtual controllers.
  3. Allows using controller as virtual Switch Pro Controller.
  4. Requires Xidi wrapper.
  5. ReWASD allows to use Mobile gyroscope as mouse or emulated DualShock 3, DualShock 4 or Switch Pro Controller gyro. Supports attachments which emulate PlayStation or Switch controllers.
  6. Steam Link mobile application allows to remap phone gyro to mouse or sticks inputs. Supports attachments which emulate PlayStation or Switch controllers.
reWASD
xʙᴏx button can be remapped.
Support Impulse Trigger Vibration.
Can emulate the DualShock 4 to play PS4 Remote Play, PS Now or DualShock 4 compatible games.
Not free of charge. 7-day trial.
Custom configs for Xbox Wireless controller can be found in official Community Configs Library maintained by reWASD users.
macOS
Use the 360Controller driver or Xbox One Controller Enabler.
On macOS Catalina (10.15) or later, Bluetooth support is available natively.
==== Linux ====:Natively supported by distros using Linux kernel 3.17 (or later).
Xow is a Linux user mode driver for the Xbox One wireless dongle. It communicates with the dongle via libusb and provides joystick input through the uinput kernel module. The input mapping is based on existing kernel drivers like xpad.
Steam
Controller can be found in Supported Controller Database and it's correctly recognizable as Xbox One controller.
Steam Input can support the impulse trigger using the Windows.Gaming.Input when the Xbox Extended Feature Support driver is installed through Steam.
Steam Link compatibility:
Works without any drivers on any operating system that supports Steam.
Can be used just to send input from a controller to a PC. Go into Streaming options, hit 𝗬 and disable video and audio streaming.
Controller connected via USB works as expected.
Newer versions (2016 onward, beginning with Model 1708) can be paired natively using Bluetooth.
Steam Link has experimental support for the wireless adapter, and it works through VirtualHere too (Model 1537 and 1697).
The controller supports Rumble over Bluetooth after update.
May not work great unless the streaming device is connected to LAN or a low latency Wi-Fi.
Chat Headset
Stereo Headset Adapter
Chatpad
Play and Charge Kit
Similar to the Xbox 360 version, the Play and Charge Kit (Model 1556/1727) is the official rechargeable battery pack for Xbox One controllers; it includes both the battery, which is installed in the existing battery compartment, and a charging cable, which allows players to charge the controller while playing a game. The cable is a standard USB-A to micro-USB cable 9 ft (2.7 m) long, equipped with an indicator light that provides state of charge information, glowing orange while charging and green or white when complete. The bundled Xbox One Li-Ion Rechargeable Battery has a 1400 mAh capacity at 3.0 V (4.2 Wh).
Controller:Xbox Wireless Controller - PCGamingWiki PCGW - bugs, fixes, crashes, mods, guides and improvements for every PC game
