| Xbox Series X | |
| Manufacturer | Microsoft |
| Code name | Project Scarlett |
| Release date | November 10, 2020 |
| Xbox Fault Finding Using I2C | Troubleshooting/Diagnostics | 2. Medium |
| Xbox Series X No Video Repair | Logic Board | Soldering | 3. Hard |
| Xbox Series X powers off during gameplay repair | SSD | Part replacement | 2. Medium |
| Xbox Series X powers off shortly after powering on repair | Logic Board | Soldering | 3. Hard |
Xbox Series X Console and Controller
Xbox Series X top close up
With expansion card installed
Xbox series X installing expansion card
Xbox series X back
Xbox Series X IO Ports
Xbox Series X IO closeup
Seagate Xbox expansion card inserted
Xbox Series X (with White background)
Joey Does Tech -
Part Numbers
- 20535-010E-02 I-PEX Evaflex 5-VS series connector (aka nexus connector or push-button connector)
- NB7N621M IC HDMI Encoder Possible source (https://www.mobilesentrix.com/nb7nq621-ic-displayport-redriver-for-xbox-series-x) and Here in the UK
- M1087810 HDMI Connector
An Alternative ESD Booster IC has been developed that brings back functionality and has been released Here
