Xbox Series X
Xbox Series X
Manufacturer Microsoft
Code name Project Scarlett
Device type Game Console
Joey Does Tech -
Part Numbers
  • 20535-010E-02 I-PEX Evaflex 5-VS series connector (aka nexus connector or push-button connector)
An Alternative ESD Booster IC has been developed that brings back functionality and has been released Here
