IPhone 7
Revision as of 14:58, 14 January 2024 by Ethan (talk | contribs) (Release date)
IPhone 7
Manufacturer Apple
Code name
Device type Phone
Soldering
3. Hard
Soldering
3. Hard
Soldering
Teardown
Part replacement
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
2. Medium
Soldering
3. Hard
Soldering
3. Hard
NAND
Soldering4. Specialist
