Raspberry Pi
Revision as of 20:45, 13 January 2024 by ASRepairs (talk | contribs)
Raspberry Pi
Manufacturer Raspberry Pi Foundation
Code name
Release date 2012-02-29
Device type Other
About/Info
The Raspberry Pi is an inexpensive single-board computer with an ARM CPU.
Components used in one Raspberry Pi model are often reused in the next model, which is why many solutions work for multiple models.
Raspberry Pi LAN9514Circuit2. Medium
Raspberry Pi MXL7704Circuit2. Medium
Raspberry Pi PSU TestMethod1. Easy
Raspberry Pi RAM TestTroubleshooting/Diagnostics1. Easy
All voltages pressent, doesn't boot and there the ACT LED is completely offQSBP K7DSoldering3. Hard
Raspberry Pi Faulty PAM2306 RepairMain Logic BoardSoldering3. Hard
Raspberry Pi Issues Booting or Reading SD Card Repair
Raspberry Pi WiFi antenna has broken off the board Repair
Raspberry Pi runs fine, but the USB ports have no 5V power RepairMain Logic BoardSoldering3. Hard
Raspberry Pi runs fine, but there is no picture when using HDMI Repair
External Sources
Raspberry Pi 1
Raspberry Pi 2
Raspberry Pi 3
Raspberry Pi 4
Raspberry Pi Zero
Raspberry Pi Zero 2
