IPhone 7
Revision as of 17:45, 10 January 2024 by ASRepairs (talk | contribs)
IPhone 7
Manufacturer Apple
Code name
Release date
Device type Phone
Soldering
3. Hard
Soldering
3. Hard
Soldering
Teardown
Part replacement
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
2. Medium
Soldering
3. Hard
Soldering
3. Hard
NAND
Soldering4. Specialist
