| IPhone 7 | |
| Manufacturer | [[:Category:|]] |
| Code name | |
| Release date | |
| Device type | |
External Sources
- How To Diagnose & Fix an iPhone 7 That Does Not Charge, Takes 0.006A via USB
- How To Fix an iPhone 7 Stuck In DFU Mode. iTunes Error Code 4014
- How To Fix an iPhone 7 That Does Not Turn On
- How To Fix an iPhone 7 That Does Not Turn On, urrent jumps back and forth from 0 A to 320 mA, then 0 A to 1.4 A, then 0 A to 500 mA, and so on
- How To Fix an iPhone 7 That Is Randomly Restarting
- How To Fix an iPhone 7 That Restarts When You Make A Call
- How To Fix an iPhone 7 With No Image, Turns On But No Display
- How To Fix an iPhone 7 With No Touch
- How To Fix iPhone 7 That Has No Backlight or Dark Spot On Screen
- How To Fix iPhone 7 That Is Stuck Always Searching or No Service After Audio IC Repair Attempt
- How To Fix iPhone 7 Unable To Activate Issue
- How To Fix iPhone 7 With A Home Button That Will Rapid Click When You Press It
- How To Fix iPhone 7 With Grayed Out Speaker Icon, Audio IC Repair
- How To Fix iPhone That Is Bootlooping. iTunes Error Code 9
- How To Recover Original Sysconfig Data from iPhone
- How to fix iPhone 7 that does not turn on, hangs at 0.020–0.030 A after you prompt to boot on DC Power Supply
- IPhone Charging Circuit Diagnostics Guide
- Parts that are serialized on iPhones
