There are many reasons that could cause an iPhone 14 Pro and iPhone 14 Pro Max to randomly restart every few minutes.
For the iPhone 14 Pro series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 14 Pro series are:
Proximity Flex - This is the flex that is attached to the screen. It can easily be liquid damaged or torn during a screen replacement.
Charging Port Flex - This is the flex towards the bottom of the phone. It is easily damaged with a drop & the back glass is breaks. Or when someone has repaired the back glass.
Power Button Flex - This is the flex that wraps around the logic board & controls the power button.
2 Layer Sandwich - Requires the bottom layer of the 2 layer motherboard. If the Gyro U7300 is not detected, it will restart. It could have ripped pads on the top board for the Gyro lines.
After a back glass repair, the iPhone will restart on its own every few minutes
After a screen repair, the iPhone will bootloop every 3 minutes
After replacing the charging port flex, the device will auto restart on its own randomly.
The iPhone will reboot randomly when using it.
The iPhone will seem to freeze and restart every 2-5 minutes.
If you see:
0x800000 - it's the Proximity Flex Cable
Make sure this flex is plugged in
Check that no flex is torn, liquid damaged, defective
Test with OEM or Premium. Aftermarket Flexes have a high defect rate
Diode mode the FPC connectors for any faults
0x400000 - It's the Charging Port Flex
0x100000 - It's the Power Button Flex
0xc00000 - It's the Prox Flex and Charging Port Flex
Make sure both flex cables are plugged in
0x180000 - It's the Prox Flex and Power Button Flex
0x140000 - It's the Power Button and Charging Port Flex
0x1c0000 - It's the Charging Port and Power Button Flex and Prox Flex
Make sure all 3 flex cables are plugged in
iPhone 14 Pro Max will restart when the Gyro is not detected on the top board, giving 0x20000 panic logDiode mode the FPC connectors for any faults
0x20000 - It's a sandwich board issue.
This means the sandwich board has separated. It could require a sandwich reball or a bottom board swap.
Check Gyro U7300
Check the pads for the Gyro U7300: 542, 543, 544, 545, 546, 6, 248
0x41 - It's a battery data issue.
Sometimes you'll see the battery percentage fluctuate or you'll randomly get a "non-genuine" message.
Check the battery connector pins. Sometimes they can bend out & battery won't make good contact.
Diode mode the battery connector pins & compare them to known good board
Test with a known good battery
Replace the battery connector
iPhone 14 Pro Max - This panic log says 0x41, which is related to battery data is missing.Example of what you'll see in a panic-full file, where when there's a bad prox flex and bad charging port flex causing the 3 min restart.
Example of what you'll see in a panic-full file, where when there's a bad prox flex and bad power button flex causing the 3 min restart.
Bad or damaged flex
Low quality aftermarket flex
Other flex cables that are Liquid Damaged
Please note: You MUST have the required flex cables, (Prox flex, Charging port flex, Power Button Flex, Sandwich reballed) plugged in. Otherwise, it WILL restart. You cannot troubleshoot this step by unplugging the bad flex.
