Xbox Series X
Revision as of 14:47, 6 September 2025 by Tiago199988 (talk | contribs) (→‎More Information/External Sources)
Xbox Series X
Manufacturer Microsoft
Code name Project Scarlett
Device type Game Console
Joey Does Tech -
Part Numbers
