Xbox Elite Wireless Controller Series 2 | |
Manufacturer | Microsoft |
Code name | Model 1797 |
Release date | November 4, 2019 |
Device type | Game Console |
Type | Difficulty | |
What's this Share button on my controller? |
- The Elite Series 2 includes many of the features included in the original Elite, such as an interchangeable D-Pad and thumb sticks. The controller also includes new adjustable tension thumb sticks, shorter hair trigger locks and new rubberized grips. The controller was also bundled with its own carrying case that doubles as a charger. The controller also includes a built-in rechargeable battery.
- Plans for a revised version of the Elite controller were leaked in January 2018, with a number of new features, including USB-C connector, and other hardware improvements such as three-level Hair Trigger Locks, adjustable tension for the thumbsticks, revised rubber grips, three user-defined profile settings, and Bluetooth connectivity, which had been introduced with the revised Xbox One S controller in 2016. At E3 2019, Microsoft announced they would begin taking pre-orders for the Xbox Elite Wireless Controller Series 2; the controller would be available starting on November 4, 2019. In general, accessories (such as the thumbs ticks and paddles) are not interchangeable between the Series 2 and Series 1 Elite controllers. The case bundled with the Elite 2 included a removable charging dock (Model 1924) for the controller's built-in battery and a pass-through to connect a USB-C cable with a port on the dock.
Firmware updates
- Either Windows 10 PC with the App, Xbox One, or Xbox Series X|S is required to update controllers' firmware.
- To update firmware on the controller, install Xbox Accessories App from Microsoft Store and connect the controller either with cable or wireless adapter.
Technical information
- Device name: Xbox One Elite Controller, HWID: 045E:0B00 (USB), 045E:0B05 (Bluetooth), 045E:0B22 (Bluetooh Low Energy)
- See also Xbox Wireless Controller for the device name and HWID for the Xbox Wireless Adapter.
Input lag
- Wired connection input lag: 7.2 ms for button press and 6.5 ms for joystick move. Values can be improved to 5.0 ms by overclocking controller's polling rate to 1000Hz.
- Wireless connection input lag: 7.6 ms for button press and 7.1 ms for joystick move. Bluetooth connection input lag: 11.3 ms.
Chat Headset
Stereo Headset Adapter
Chatpad
Xbox Wireless Adapter for Windows
