Nintendo Wii SD Card does not read
Device Nintendo Wii
Affects part(s)
Needs equipment
Difficulty ◉◌◌◌ Easy
Type
  • SD Card does not read
  • Check FIL43
  • Check continuety between pins CD and CD/WP. When the SD card is inserted, it connects these 2 pins to tell the system that an sd card is inserted. If there is no continuity then the sd card slot is broken. Either run a jumper wire between both pins or replace the slot.
Guide imported from the old wiki
