Nintendo Wii Disc Drive Repair
Device Nintendo Wii
Affects part(s) Disc Drive
Needs equipment
Difficulty
Type
Guide to fix multiple problems on the disc drive
Issue Explanation Possible Repair Actions
Disc does not spin Disk does not spin which prevents the disc from being read Verify disc spin motor is not seized, potentially try a Gamecube disc if your Wii supports it, if not difference please refer to next steps. Verify that you can see the laser move back and forth and that you can also see the red laser. If you do not see the red laser light, replace the laser. If the laser does not move back and forth, replace the laser stepper motor. If you can see both the red laser light and that it moves back and forth, make sure to clean it with isopropyl alcohol and a cotton swap (q-tip,) if still doesn't work, replace laser. Note: A faulty laser can prevent the disc motor from spinning on the software side.
Wii doesn't accept Gamecube discs; does not eject GC discs Gamecube disc does not properly insert and seat in the Wii disc drive This is mostly caused by a bent top disc drive cover, which does not allow the plastic mechanism to revert back to the Gamecube disc size OR the mechanism is seized due to dust, dirt or other debris, clean/replace.
Laser seems to work, but doesn't read Laser visually works, but discs are not read(ie. Laser moves back and forth and visually looks good) Verify laser POT using an ohm meter, 600 ohms is ideal, adjust very slowly, an 1/8th turn can result in increasing a hundred if not more ohms. If laser POT is within 50 ohms of 600 and still doesn't read properly and has been cleaned with isopropyl alcohol (99% preferably) and a cotton swap (q-tip), proceed to replace laser.
Dual-Layer disc doesn't read A dual-layer disc (ie. Super Smash Bros Brawl, or 12 others, does not read) Verify laser POT using an ohm meter, 600 ohms is ideal (especially for dual-layer discs,) adjust very slowly, an 1/8th turn can result in increasing a hundred if not more ohms. Clean laser lens with isopropyl alcohol and a cotton swap (q-tip), if the laser still doesn't read, replace and retest.
Disc Drive shows no signs of life The disc drive does not make any sounds, or signs of life (ie. Disc motor on startup, sounds upon insertion of disc, etc.) Verify power and data connections from Wii to Disc drive are even and connected properly. If connected properly, visually inspect board, look for missing MCC (Monolithic ceramic capacitors,) bent/damaged pins on chips, corrosion, or any other damage, be thorough. If visual inspection comes up fine proceed to replace board, or check continuity on the pins for power/data from Wii to disc drive on your discretion. To replace the board, unscrew the two philips screws holding the board to the disc drive, disconnect the disc motor cable from the board, laser cable and disc insertion sensor cable, desolder the disc insertion motor cables (red and brown), desolder laser stepper motor cables (white, blue, grey, and yellow)-- remember to document correct order when desoldering and proceed to replace in reverse order.
Loud disc drive Disc drive makes loud noises and may not work correctly Disassemble and clean disc drive, look for areas that have moving parts (ie. laser motor or the disc insertion motor and it's connected components.) Issues could be caused by dirt, debris, foreign objects, or lack of lubrication on rails. This may be difficult to diagnose and repair.
Guide Imported from the old wiki
