| IPhone XS Freezes When Last Digit of Pin Code is Entered | |
| Device | IPhone XS, IPhone XS Max |
| Needs equipment | |
- Phone boots fine
- Type in your pin code & at the last digit, it freezes, keeping that digit highlighted for about 30-60 seconds
- Then the screen restarts and you're back at the pin code screen.
- Usually it's a sandwich issue, so follow the above "No Touch" steps to solve the problem
- Sandwich reball
- Or Bottom Board Swap
- If you do a bottom board swap, without transferring the original NFC, the phone will go through a "swipe to recover" screen in most cases, where you put in the pin code, it loads a white "Attempting Data Recovery" screen & takes about 10-20 minutes.
- This is basically the operating system rewriting the NFC chip, so it can unlock.
- Then, the phone will work fine afterwards
Migrated from old Wiki
