IPhone XS Freezes When Last Digit of Pin Code is Entered
Device IPhone XS, IPhone XS Max
Affects part(s) Motherboard
Needs equipment
  • Phone boots fine
  • Type in your pin code & at the last digit, it freezes, keeping that digit highlighted for about 30-60 seconds
  • Then the screen restarts and you're back at the pin code screen.
  • Usually it's a sandwich issue, so follow the above "No Touch" steps to solve the problem
    • Sandwich reball
    • Or Bottom Board Swap
  • If you do a bottom board swap, without transferring the original NFC, the phone will go through a "swipe to recover" screen in most cases, where you put in the pin code, it loads a white "Attempting Data Recovery" screen & takes about 10-20 minutes.
  • This is basically the operating system rewriting the NFC chip, so it can unlock.
  • Then, the phone will work fine afterwards
Migrated from old Wiki
