| | Affects part | Type | Difficulty |
| How To Diagnose & Fix an iPhone 7 That Does Not Charge, Takes 0.006A via USB | Main Logic Board | BGA Soldering | 3. Hard |
| How To Fix an iPhone 7 Stuck In DFU Mode. iTunes Error Code 4014 | Main Logic Board | BGA Soldering | 3. Hard |
| How To Fix an iPhone 7 That Does Not Turn On | Main Logic Board | BGA Soldering Teardown Part replacement | 3. Hard |
| How To Fix an iPhone 7 That Does Not Turn On, urrent jumps back and forth from 0 A to 320 mA, then 0 A to 1.4 A, then 0 A to 500 mA, and so on | Main Logic Board | BGA Soldering | 3. Hard |
| How To Fix an iPhone 7 That Is Randomly Restarting | Main Logic Board | BGA Soldering | 3. Hard |
| How To Fix an iPhone 7 That Restarts When You Make A Call | Main Logic Board | Part replacement | 1. Easy |
| How To Fix an iPhone 7 That Suddenly Developed a No Service Issue. Baseband Repair | Main Logic Board | BGA Soldering | 3. Hard |
| How To Fix an iPhone 7 With No Image, Turns On But No Display | Main Logic Board | BGA Soldering | 3. Hard |
| How To Fix an iPhone 7 With No Touch | Main Logic Board | BGA Soldering | 3. Hard |
| How To Fix iPhone 7 That Has No Backlight or Dark Spot On Screen | Main Logic Board | BGA Soldering | 3. Hard |
| How To Fix iPhone 7 That Is Stuck Always Searching or No Service After Audio IC Repair Attempt | Main Logic Board | BGA Soldering | 3. Hard |
| How To Fix iPhone 7 Unable To Activate Issue | Main Logic Board | BGA Soldering | 3. Hard |
| How To Fix iPhone 7 With A Home Button That Will Rapid Click When You Press It | Home Button | BGA Soldering | 2. Medium |
| How To Fix iPhone 7 With Grayed Out Speaker Icon, Audio IC Repair | Main Logic Board | BGA Soldering | 3. Hard |
| How To Fix iPhone That Is Bootlooping. iTunes Error Code 9 | Main Logic Board | BGA Soldering | 3. Hard |
| How to fix iPhone 7 that does not turn on, hangs at 0.020–0.030 A after you prompt to boot on DC Power Supply | Motherboard | Soldering | 3. Hard |
