How To Fix an iPhone 13 That Randomly Restarts
Device iPhone 13 Mini, iPhone 13, iPhone 13 Pro, iPhone 13 Pro Max
Difficulty ◉◌◌◌ Easy
Type Part replacement
There are many reasons that could cause an iPhone 13 Mini, iPhone 13, iPhone 13 Pro and iPhone 13 Pro Max to randomly restart every few minutes. For the iPhone 13 series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 13 series are:
  • Proximity Flex - This is the flex that is attached to the screen. It can easily be liquid damaged or torn during a screen replacement.
  • Board Issue (iPhone 13 Mini Only) - Requires the bottom layer of the 2 layer motherboard.
If you see:
  • 0x1000 - it's the proximity flex cable
  • 0x800 - It's the charging port flex
  • 0x1800 - It's both, the Charging Port Flex AND Prox Flex
    • This means both parts are having issues. You'll need to check both parts are good & not damaged.
    • Make sure both flexes are plugged in
  • 0x4000 - Battery Data Line Issue
    • Sometimes you'll see the battery percentage fluctuate or you'll randomly get a "non-genuine" message.
    • Check the battery connector pins. Sometimes they can bend out & battery won't make good contact.
    • Diode mode the battery connector pins & compare them to known good board
    • Test with a known good battery
    • Replace the battery connector
  • 0x400 - iPhone 13 Mini only - It's a bottom board issue. The iPhone 13 mini needs to communicate with the gyroscope in order to function correctly and not restart every 3 minutes. Rebuilding pads 207, 208, 502, 503, 504, 527, 528 is all that is needed from the bottom board.
Example of what you'll see in a panic-full file, where when there's a bad prox flex causing the 3 min restart. If you see this same error, then it's likely the proximity flex.
Example of what you'll see in a panic-full file, where when there's a bad charging port flex causing the 3 min restart. If you see this same error, then it's likely the charging port flex.
  • Bad or damaged flex
Please note: You MUST have the required flex cables, Power Button & Charging Port, plugged in. Otherwise it WILL restart. You cannot troubleshoot this step by unplugging the bad flex. (This does not apply to the Wi-Fi antenna flex.)
