GTX 1080Ti Not detected repair (Short on 1.8V)
Device GTX 1080Ti, GTX 1080Ti SC2 Hybrid, GTX 1080
Affects part(s) Capacitor C83 22uF 6.3V 0603
Needs equipment multimeter, soldering iron, soldering station, thermal camera.
Short circuit measurement on 1.8V rail on EVGA 1080Ti SC2 Hybrid (Figure 1)
Shorted C83 Capacitor 22uF 6.3V 0603 (Figure 2)
Thermal camera view of the capacitor while injecting voltage (Figure 3)
  • Card is not detected by the motherboard
  • Fan does not spin
  • Disassemble the card
  • With your multimeter, measure the resistances of the voltage rails, refer to this or this page for reference measurements
  • You should measure a short circuit on 1.8V rail (Figure 1), if not, this guide is not applicable to your problem
  • Inject 1V to the rail and see what heats up using a thermal camera or other short finding methods.
    • In this case, it was a capacitor under the core (Figure 2, 3)
    • You might have a different capacitor that is shorted or the core itself, if you feel the core itself is getting warm, it's a dead core.
If the short is not gone after de-soldering, the core could be dead, repeat the diagnostic steps.
