How To Fix an iPhone 16 That Randomly Restarts
Revision as of 00:18, 6 July 2025 by VCCBoardRepairs (talk | contribs) (iPhone 16 3 min restart solution guide)
Device IPhone 16, IPhone 16 Plus
Affects part(s) Flex cable
Needs equipment
Difficulty ◉◌◌◌ Easy
Type Teardown
There are many reasons that could cause an iPhone 16 and iPhone 16 Plus to randomly restart every few minutes.
For the iPhone 16 Base Model series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
This may be different than the iPhone 16 Pro and 16 Pro Max. For those models, please visit this guide: How To Fix an iPhone 16 Pro That Randomly Restarts
The most common for iPhone 16 and 16 Plus are:
  • Air Pressure Sensor - This part is located at the bottom of the housing & connects to the charging port flex. If it gets physically damaged or water damaged, it can cause 3 min restarts
  • Wireless Charging Flex - The flex that's attached to the back glass. It must be plugged in & not damaged, otherwise it will restart every 3 minutes
  • Bad Battery - If the battery is defective or goes bad, it can cause restarting problems.
  • iPhone 16 1572864 Panic Log Example
    iPhone 16 1572864 Panic Log Example for Charging Port or Air Pressure Sensor fault
  • iPhone 16 Panic Log Example for Back Glass fault
For this model, look for where it says "SMC PANIC - ASSERT" ... "Sensor Array" ..
If you see:
  • 1572864 or 524288 - It's related to the Charging Port Flex
    • iPhone 16 Air Pressure Sensor. If not connected or damaged, it will cause panic log 1572864
      Check the bottom mic/air pressure sensor module is connected
    • Test with OEM or Premium parts.
      • Aftermarket Flexes have a high defect rate
    • If water damaged:
      • 1. Check the taptic engine. You can test with it unplugged.
      • 2. Check the air pressure sensor module is not corroded or damaged
      • 3. Check the FPC for corrosion or loose pins
    • Diode mode the FPC connectors for any fault
  • 2097152 - It's related to the Wireless Charging Flex
    • iPhone 16 Back Glass - If you don't have this flex plugged in, it will cause 3 min restarts with panic log 2097152. The important part of the flex is the small IC where the red arrow is
It is also a good idea to keep a known good charging port flex in your bench, for testing only. There are reports of even NEW flexes being bad. So you have to keep known good flexes on hand at all times, so you don't waste your time troubleshooting with possibly bad flexes.
  • Bad or damaged flex
Please note: You MUST have the required flex cables, (Charging port flex, etc) plugged in. Otherwise, it WILL restart. You cannot troubleshoot this step by unplugging the bad flex.
