How To Fix an iPhone 11 Pro That Randomly Restarts
Revision as of 22:22, 5 November 2023 by ASRepairs (talk | contribs)
Device iPhone 11 Pro, iPhone 11 Pro Max
Needs equipment Screwdrivers, known good parts, spunger
Difficulty ◉◌◌◌ Easy
Type Part replacement
There are many reasons that could cause an iPhone 11 Pro or iPhone 11 Pro Max randomly restart every few minutes. For the iPhone 11 Pro or Pro Max, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 11 Pro series are:
  • Bad or Defective Battery - If the phone is not showing a percentage at the top of the screen, it means the battery data isn't being read by the device, causing the device to restart. So if you see your iPhone 11 Pro says it's charging at 0%, that could be why it's restarting.
  • Charging Port Flex - This is the flex towards the bottom of the phone which is slightly exposed behind the back glass. It is easily damaged with a drop & broken back glass, or by a technician during a back glass repair.
  • Damaged or Defective Power Button - There is a secondary mic (mic2) that is on the power button flex. It is easily damaged, especially after back glass repair, causing the mic to be disconnected & the phone will restart when it's not detected.
  • After a battery replacement, the iPhone will boot-loop every 3 minutes
If you see:
  • TG0B or TG0V - It's battery related:
    • The battery is defective or has failed
    • The battery connector itself is damaged, warped or broken
    • Check the battery connector on the charging port flex
    • The battery connector data lines are missing.
      • Check the battery data pin (PMU_TO_BATTERY_SWI) for a diode mode reading.
  • Prs0 or Mic1 - It's the charging port flex.
    • Test with known good charging port flex.
    • Check for damaged or missing resistors around the charging port connector
  • Mic2 - It's related to the mic on the power button flex
    • Test with a known good power button flex
    • Check for pry damage on all the small components near the connector
An example panic log, showing "Missing sensors: Prs0", which means it has a bad charging port flex.
  • Bad or damaged flex
