| How To Fix an iPhone 11 Pro That Randomly Restarts | |
| Device | iPhone 11 Pro, iPhone 11 Pro Max |
| Needs equipment | Screwdrivers, known good parts, spunger |
| Type | Part replacement |
There are many reasons that could cause an iPhone 11 Pro or iPhone 11 Pro Max randomly restart every few minutes. For the iPhone 11 Pro or Pro Max, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 11 Pro series are:
- Bad or Defective Battery - If the phone is not showing a percentage at the top of the screen, it means the battery data isn't being read by the device, causing the device to restart. So if you see your iPhone 11 Pro says it's charging at 0%, that could be why it's restarting.
- Damaged or Defective Power Button - There is a secondary mic (mic2) that is on the power button flex. It is easily damaged, especially after back glass repair, causing the mic to be disconnected & the phone will restart when it's not detected.
- After a battery replacement, the iPhone will boot-loop every 3 minutes
If you see:
- Check the battery connector on the charging port flex
- Check the battery data pin (PMU_TO_BATTERY_SWI) for a diode mode reading.
- Mic2 - It's related to the mic on the power button flex
- Test with a known good power button flex
- Check for pry damage on all the small components near the connector
- Bad or damaged flex
