Nintendo Switch Error Code 2134-0501 Repair
Revision as of 18:47, 24 March 2025 by JKYOHO (talk | contribs) (→‎Solution)
Device Nintendo Switch
Fixing a problem with a Nintendo Switch in the form of error code 2134-0501
  • Error Code 2134-0501
In most scenario, this 21xx-xxxx error code is referred to bootup self-check failure, and by most case due to M92T36 PD control ic, replace it with known good one.
  • Check voltages around MAX77620 (esp 1v05 rail) Reference, if voltages good replace MAX17050 fuel gauge
