| GTX 1080Ti Not detected repair (Short on 1.8V) | |
| Device | GTX 1080Ti, GTX 1080Ti SC2 Hybrid, GTX 1080 |
| Affects part(s) | Capacitor C83 22uF 6.3V 0603 |
| Needs equipment | multimeter, soldering iron, soldering station, thermal camera. |
- Card is not detected by the motherboard
- Fan does not spin
- Disassemble the card
- With your multimeter, measure the resistances of the voltage rails, refer to this or this page for reference measurements
- You should measure a short circuit on 1.8V rail (Figure 1), if not, this guide is not applicable to your problem
- Inject 1V to the rail and see what heats up using a thermal camera or other short finding methods.
- In this case, it was a capacitor under the core (Figure 2, 3)
- You might have a different capacitor that is shorted or the core itself, if you feel the core itself is getting warm, it's a dead core.
If the short is not gone after de-soldering, the core could be dead, repeat the diagnostic steps.
