IPhone 7 Plus
Revision as of 04:06, 17 January 2024 by Oolfs (talk | contribs) (Remove a period from "Release date")
IPhone 7 Plus
Manufacturer Apple
Code name
Device type Phone
Soldering
3. Hard
Soldering
3. Hard
Soldering
Teardown
Part replacement
3. Hard
Soldering
3. Hard
Soldering
3. Hard
How To Fix an iPhone 7 That Suddenly Developed a No Service Issue. Baseband RepairMain Logic BoardBGA
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
2. Medium
Soldering
3. Hard
Soldering
3. Hard
NAND
Soldering4. Specialist
