Xbox Series X No Video Repair
Revision as of 16:12, 16 January 2024 by ASRepairs (talk | contribs)
Device Xbox Series X
Affects part(s) Logic Board
Needs equipment
No Display / No Video Output
Pinout for bypassing the ESD Protection IC
  • No Display / No Video Output
  • Put your Xbox into low resolution mode. Low Resolution mode demonstration.
  • Replace HDMI Cable
  • Inspect HDMI Port for Damage
  • Check EMI Filters Below Port
  • Check HDMI Encoder (Possibly Not Available to Purchase)
  • Check ESD Protection IC (Underside of Motherboard) - You could also bypass the ESD Protection IC by using the pinout shown.
  • Check 2151 5v Transistor. Can Be Replaced with Similar Transistor from OG Xbox One Ethernet Circuit
