| Xbox Series X No Video Repair | |
| Device | Xbox Series X |
| Needs equipment | |
No Display / No Video Output
- No Display / No Video Output
- Put your Xbox into low resolution mode. Low Resolution mode demonstration.
- Replace HDMI Cable
- Inspect HDMI Port for Damage
- Check EMI Filters Below Port
- Check HDMI Encoder (Possibly Not Available to Purchase)
- Check ESD Protection IC (Underside of Motherboard) - You could also bypass the ESD Protection IC by using the pinout shown.
- Check 2151 5v Transistor. Can Be Replaced with Similar Transistor from OG Xbox One Ethernet Circuit
