Raspberry Pi MXL7704 | |
Type | |
Device(s) | Raspberry Pi |
Difficulty |
The MXL7704 is a programmable quadruple step-down DC/DC converter that is used in the following Raspberry Pi models:
- Raspberry Pi 3 (A+ and B+) (MXL7704-R3 version)
- Raspberry Pi 4 (all) (MXL7704-P4 version)
The MxL7704-AQB, MxL7704-XQB, MxL7704-R3 and MxL7704-P4 might be replaceable by the one-time programmable (OTP) successor MxL7704-BQB
The new model may be (one time) programmable to match the specific raspberry pi model default values.
Common cause of failure
If the Pi's 5V pin is shorted to the neighboring 3.3V pin, the MXL7704 will try to clamp the voltage on the 3.3V line. This destroys the MXL7704 chip, leaving the 3.3V line permanently shorted to GND.
Configuring
The MXL7704 chip can be configured via an I2C interface. The I2C address depends on the version of the chip:
Version | Address |
AQB and XQB versions | 0x2D
R3 version (Raspberry Pi 3) | 0x1D
P4 version (Raspberry Pi 4) | 0x1B
Despite having a different I2C address, the R3 version of the chip will be correctly recognized by the OS if it's installed in a Raspberry Pi 4.
Note that any changes made to the configuration are not permanently stored. Every time the chip is powered off, its default configuration is restored. Different versions of the chip have different default configurations:
Model | Default configuration |
Raspberry Pi 3 (A+ and B+) |
pi@raspberrypi:~ $ i2cdump -y 1 0x1d 0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef 00: a0 01 e4 27 43 57 27 00 00 00 02 00 XX XX XX XX ???'CW'...?.XXXX 10: a5 a5 5a c0 c0 e4 1f 48 10 a9 7f 67 00 00 XX XX ??Z????H???g..XX |
Raspberry Pi 4 |
pi@raspberrypi:~ $ i2cdump -y 1 0x1b 0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef 00: a0 01 e4 27 43 57 27 00 00 00 02 00 XX XX XX XX ???'CW'...?.XXXX 10: a5 a5 5a b0 a5 e4 de 48 10 e9 5e 66 00 27 XX XX ??Z????H??^f.'XX |
Here's the meaning of the two default configurations (for more info, see the datasheet linked at the bottom of the page):
Address | Setting | Raspberry Pi 3A+ / 3B+ | Raspberry Pi 4 | ||
Value | Meaning | Value | Meaning | ||
0x02
Phase interleaving | 0xe4
1 → 2 → 3 → 4 | 0xe4
1 → 2 → 3 → 4 |
0x10
V_out LDO | 0xa5
3.3V | 0xa5
3.3V |
0x11
V_out buck 1 | 0xa5
3.3V | 0xa5
3.3V |
0x12
V_out buck 2 | 0x5a
1.8V | 0x5a
1.8V |
0x13
V_out buck 3 | 0xc0
1.2V | 0xb0
1.1V |
0x14
V_out buck 4 | 0xc0
1.2V | 0xa5
1.03V |
0x15
Buck Sequence Group Assignment | 0xe4
0xe4
0x16
0x1f
0xde
0x17
0x48
0x48
0x18
PG2 Routing | 0x10
buck 4 | 0x10
buck 4 |
0x19
0xa9
0xe9
The following pads can be used to access the I2C interface:
Model | SDA | SCL |
Raspberry Pi 3 (A+ and B+) | PP60
PP59
Raspberry Pi 4 | The relevant traces |
Compute Module 4 (CM4)
Since the LDO VIN is shorted to ground by CM4's layout design, the MxL7704-P4 (where the LDO is disabled by default programming) has to be used.
When using the MxL7704-R3 variant (which is the one available in AliExpress), the CM4 will not start since the LDO is assigned to group0 and cannot start - so group0 cannot start. With it all the buck converters stay disabled.
A tested alternative for using MxL7704-R3 for repairing CM4 is to disconnect Pin8 (LDO) and Pin7 (VIN) from the board and connect it (Pin7) permanently with +5V instead.
References
- ↑ MXL7704 datasheet, MaxLinear, Inc., 2018
- ↑ MXL7704 Product Discontinuation Notice, MaxLinear, Inc., 2021
- ↑ MXL7704-BQB datasheet, MaxLinear, Inc., 2022
