Nintendo Switch CC1/CC2 lines are shorted to ground after replacing the M92T36 IC and connecting the Switch charger Repair
Revision as of 16:26, 13 January 2024 by ASRepairs (talk | contribs)
Device Nintendo Switch
Affects part(s)
Needs equipment
Difficulty
Type
CC1/CC2 lines measure less than 10 ohms to GND after replacing the M92T36 IC and connecting the Switch charger
  • Sub 10 Ohms to GND on the CC1/CC2 lines
Replace the 3v3 buck converter IC (next to the Audio IC) Source: https://gbatemp.net/threads/fried-multiple-m92t36.572667/
