Nintendo Switch Console appears to have no power, but makes sounds when touch screen is tapped Repair
| Nintendo Switch Console appears to have no power, but makes sounds when touch screen is tapped Repair | |
| Device | Nintendo Switch |
| Affects part(s) | LCD, Rippon connector |
| Needs equipment | Screwdriver set, tweezers |
| Difficulty | ◉◉◌◌ Medium |
| Type | Part replacement, Cleaning |
- Console appears to have no power, but makes sounds when touch screen is tapped
- Ensure the LCD and backlight are not damaged. Check for liquid damage around the backlight ribbon or damage to the LCD or LCD connector
- Check for shorts or damage around the LCD Driver to the left of the LCD Connector (83160722)
