Nintendo Switch Console appears to have no power, but makes sounds when touch screen is tapped Repair
Revision as of 14:27, 13 January 2024 by ASRepairs (talk | contribs)
Device Nintendo Switch
Affects part(s)
Needs equipment
Difficulty
Type
  • Console appears to have no power, but makes sounds when touch screen is tapped
  • Ensure the LCD and backlight are not damaged. Check for liquid damage around the backlight ribbon or damage to the LCD or LCD connector
  • Check for shorts or damage around the LCD Driver to the left of the LCD Connector (83160722)
