Nintendo Switch CC1/CC2 lines are shorted to ground after replacing the M92T36 IC and connecting the Switch charger Repair
| Nintendo Switch CC1/CC2 lines are shorted to ground after replacing the M92T36 IC and connecting the Switch charger Repair | |
| Device | Nintendo Switch |
| Affects part(s) | |
| Needs equipment | |
| Difficulty | |
| Type | |
- CC1/CC2 lines are shorted to ground after replacing the M92T36 IC and connecting the Switch charger
- Replace the 3v3 buck converter IC (next to the Audio IC)Source: https://gbatemp.net/threads/fried-multiple-m92t36.572667/
