IPhone 7 Plus
Revision as of 17:45, 10 January 2024 by ASRepairs (talk | contribs)
IPhone 7 Plus
Manufacturer Apple
Code name
Release date
Device type Phone
Soldering
3. Hard
Soldering
3. Hard
Soldering
Teardown
Part replacement
3. Hard
Soldering
3. Hard
Soldering
3. Hard
How To Fix an iPhone 7 That Suddenly Developed a No Service Issue. Baseband RepairMain Logic BoardBGA
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
3. Hard
Soldering
2. Medium
Soldering
3. Hard
Soldering
3. Hard
NAND
Soldering4. Specialist
